i.pca, r.mapcalc, i.rectify
imager at ccwf.cc.utexas.edu imager at ccwf.cc.utexas.edu
Mon Aug 17 17:35:24 EDT 1992
Hi (Y')all,
I have a few questions concerning some problems that I'm having using
GRASS. Hopefully some one out there might know of solutions to the
following:
1) When I try to use "i.pca" to transform 4 entire SPOT images (52 MBytes
   each) the job gets killed by the system. Is this a normal response when
   trying to carry out PCA on a large dataset or is it related to the
   problems with the porting of GRASS to the RISC 6000 platform?
2) I have been trying to ratio two SPOT images using "r.mapcalc"
   as follows r.mapcalc ratio=band3/band1 but the output image only
   has minimum value=0, maximum value=1. I have checked the band
   statistics for both bands and although I wouldn't expect the maxmimum
   theoretical range of 256*256 values I certaintly expected a greater
   range of values than 1 or 0. Is there something I need to do (like set
   number of decimal places or reference a ratio lookup table) to carry out
   image ratioing?
3) I was recently using "i.target,i.points and i.rectify" to reference a
   previously (State Plane) rectified SPOT image in ROW, COL format to
   State Plane coordinates. I would like to know if the i.rectify algorithm
   uses a third order polynomial to rectify the input images or whether
   it matches the most appropriate transformation equation to the inputted
   control point coordinates?
Thanks in advance,
Tony Gale
Research Specialist
City of Austin Electric, Tx.
