No subject
Pam Sydelko
sydelko at camelot.es.anl.gov
Fri Aug 21 09:48:11 EDT 1992
O.K. The way I extracted TM data from an 8mm tape was to first use
m.examine.tape to find out what my rows and columns were.
file 1
len: records
1536: 1 - 1
file 2
len: records
4480: 1 - 2240
file 3
len: records
4480: 1 - 2240
...etc...
len is the number of columns and records is the number of rows. The first file
is the header and should be skipped.
I then used i.tape.other to extract the data. In the Generic Tape Extraction
menu, answer the following:
tape layout
1 number of tape files to be skipped
0 number of records in remaining files to be skipped
band files
7 number of bands on the tape
data format
x band sequential (BSQ) | mark one with an X
band interleaved (BIL)|
0 if you select BSQ format and all the bands are in a single file
enter the total number of records in the file. Otherwise enter 4480 length (in bytes) of the longest record on the tape
When you are asked to select the window to extract use the row and column data
from m.examine.tape:
start row:1
end row :2240
start col:1
end row :4480
Everything else is pretty straight forward. Seems to have worked fine for
me. Hope this helps.
Pam (Thompson) Sydelko
Argonne National Laboratory
9700 S. Cass Ave. - ES/372
Argonne, Il 60439
708-252-6727
