more grey levels for XDRIVER?
    Dave Gerdes
    dpgerdes at zorro.cecer.army.mil
    Wed Dec  9 14:17:06 EST 1992
> From: martijn at scanner.frw.uva.nl
> Brian Scamman writes:
> > Is there a way to increase the number of greyscale levels available to the
> > display window?  Currently, I am able to only get six different levels.  I would
> > like to get 256 levels if it is possible.
> r.colors map=mapname color=rules
> will do the trick if your 'rules' file contains
> 0% 0 0 0
> 100% 256 256 256
> if I'm not mistaken (I haven't tried it myself)
The issue is that in fixed mode, GRAY only gets a few slots in the
color table.  If you switch to float mode: d.colormode float,
you can fill up the entire color table with gray levels.
There are problems with using float mode of course, so consider the risks.
  Dave Gerdes
  US Army Construction Engineering Research Lab
  Spatial Analysis & Systems Team
  (217) 352-6511 x591
