Weighted Buffers?
Bruce K. Wylie (303) 490 8336 wylie at gpsrv1.gpsr.colostate.edu
Thu Dec 10 08:25:45 EST 1992
The way I would approach this is have a buffer layer where 1 = 100' from
steams and 2 = 200' from steams. Then I would use r.mapcalc and its
logical if, then statements to access slope coverage and buffer coverage to
develope the third coverage, the "weighted buffer".
Regards,
Bruce Wylie
> From:	MX%"grassu-list at max.cecer.army.mil"     9-DEC-1992 16:46
> To:	WYLIE
> CC:
> Subj:	Weighted Buffers?
> Return-Path: <grass-lists-owner at max.cecer.army.mil>
> Received: from max.cecer.army.mil by GPSRV1.GPSR.COLOSTATE.EDU (MX V3.1) with
>           SMTP; Wed, 09 Dec 1992 16:46:23 MST
> Received: from amber.cecer.army.mil by max.cecer.army.mil with SMTP id AA29733
>           (5.67a/IDA-1.5); Wed, 9 Dec 1992 17:45:13 -0600
> Received: from zorro.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id
>           AA22554; Wed, 9 Dec 92 17:38:33 CST
> Received: from amber.cecer.army.mil by zorro.cecer.army.mil with SMTP id
>           AA12490 (5.67a/IDA-1.4.4 for <grassu-people at amber>); Wed, 9 Dec 1992
>           17:38:32 -0600
> Received: from max.cecer.army.mil by amber.cecer.army.mil (4.1/SMI-4.1) id
>           AA22548; Wed, 9 Dec 92 17:38:28 CST
> Received: from sprintf.merit.edu by max.cecer.army.mil with SMTP id AA29599
>           (5.67a/IDA-1.5 for <grassu-list at max.cecer.army.mil>); Wed, 9 Dec 1992
>           17:38:29 -0600
> Received: by sprintf.merit.edu (5.64/1123-1.0-X.500) id AA15117; Wed, 9 Dec 92
>           17:46:14 -0500
> Received: by sprint.com (SXG 6.0/scanf.7) with X.400 id 00f9bQkua001; 9 Dec 92
>           22:45:39 UT
> Date: 9 Dec 92 20:37:46 UT
> From:
>       /S=E.ODOHERTY/OU=R02F06A/PRMD=USDA.FS.X400/ADMD=TELEMAIL/C=US/@sprint.com
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Precedence: Bulk
> To: /OU=R02F06A/PRMD=USDA.FS.X400/ADMD=TELEMAIL/C=US/@sprint.com
> Subject: Weighted Buffers?
> Message-ID: <"PL-IXSFJG"*@sprint.com>
> I have a friend with a question who is not on the network yet, but
> here is the question:
> I need to know if GRASS can do weighted buffers, and if so what
> command(s) you use to do it.  Example:  a buffer around streams
> where if slope is greater than 40% and the ground cover is trees, the
> buffer should be 200', but if the slope is less than 40% slope and
> the ground cover is grass, the buffer should be 100'.  Clear as mud?
> Thanks for any input!!
