rim on the GRASS
Kenji Okamoto
okamoto at chigaku.souka.osakafu-u.ac.jp
Fri Dec 18 23:58:06 EST 1992
Hi, GRASS users,
I reported a rim_help problem on my port to SVR4 preveously.
This is solved by hucking the subroutine in src/rimh.f, the result
of which is included at the bottum of this letter.
The original rimh.f which I could get has some wrong coding to make the
tupple data of variable length text, in this case COMTXT in HELP_TEXT
relation.
I hope this may help someone.
If this is a FAQ, sorry.
Kenji
-------------cut here---------------------
SUBROUTINE LODROW(LINE,NC)
INCLUDE 'syspar.d'
INCLUDE '../src/ascpar.d' <<<<<<<********
C
C WRITE A LINE TO DB
INCLUDE '../src/rimcom.d'
LOGICAL RIMDM
C
PARAMETER (NW = 80/ZCW)
INTEGER LINE(NW), NC, NCR
C DATA TO HOLD THE TEXT TUPLES
PARAMETER (TPL=3+NW+2)
PARAMETER (TXTSRT=4)
COMMON /TUP/ TUPLE(TPL)
NCR = (NC - 1)/ZCW + 1
DO 120 I = 1, NCR
120 TUPLE(TXTSRT+1+I) = LINE(I)
TUPLE(TXTSRT) = NC
TUPLE(TXTSRT+1) = 0
130 IF (.NOT.RIMDM(1,'LOAD',TUPLE)) THEN
WRITE(6,1000) NC, RMSTAT
1000 FORMAT(' LOAD ERROR: ',2I5)
ENDIF
RETURN
END
-------------end here---------------------------
Kenji Okamoto | okamoto at earth.chigaku.souka.osakafu-u.ac.jp
______ __ |__ | Universiy of Osaka Prefecture, Dept. of Earth Science,
|__\/__| /|\ | Gakuen-cho 1 - 1, Sakai, Osaka 593, Japan
||_|_| | / + \ | tel(voice) +81-722-52-1161 (ext)2736 (FAX)+81-722-55-2981
