GRASS4.0 Under openwindows 3.0
Chris C Rewerts rewerts at ecn.purdue.edu
Wed Feb 26 09:03:19 EST 1992
To add a comment to what Julian Ray has noted, when I was running
on the same conditions (sparc2/sunos 4.1.2/openwin 3)
and using the newer version of XDRIVER from the updates on the moon,
I didn't get the "flashing" that was typical before, but
the black color was more gray than black. So, when I did a "d.erase
black", I got a murky gray screen. Other colors looked
a bit washed out as well, compared to how I remember them from
using XDRIVER previously... I was guessing that the flashing was
eliminated by trying to fit the grass colors in with the existing
colormap. I haven't done a lot of experimentation since getting the
newer version of XDRIVER, but I thought I would pass this comment
along since the topic came up in the mail queue.
Chris Rewerts   (rewerts at ecn.purdue.edu)
>From lists-owner at amber.cecer.army.mil Tue Feb 25 22:41:02 1992
>From: jray <jray at utkux1.utk.edu>
>Ive just installed grass4.0 on a Sparc2 running SunOS 4.1.2 and OpenWindows 3.0
>and everything seems to work fine with one exception: the colour pallete used
>by the XDRIVER and openwindows are different. Although the system works it
>creates a nuisance by "flashing" the screen colours from one colour map to
>the other as the mouse moves between the canvas and the windows. Thus, the
>colours on the canvas are incorrect with respect to the selected colours
>until the mouse is positioned in to the active frame whereupon the rest of
>the monitor takes on a rather gastly appearence.
>	Is there a fix for this or is it a problem with the owm driver?
>Julian Ray
>Transportation Research Center
>University of Tennessee
>Knoxville.
