m.dem.extract stuff...
Michael Shapiro
shapiro at zorro.cecer.army.mil
Fri Jan 10 10:32:36 EST 1992
In response to this comment:
|Regarding the m.dem.extract talk... I believe that a tape device
| is bassically regarded as one file under that particular device
| name (directory/file) In short there funtionally is no difference
| between specifying a tape device or a file.
There is a major difference between tapes and files. Tapes can
have multiple files on them (embedded EOFs between files) and
have true physical record lengths. This means that a program can
keep reading after one EOF and get more data (if there are more
files) and that read() requests for more data than is contained
in a physical record only read what is in that physical record
(and return the number of bytes read). It will not read data
from two physical records in one read() request. This is clearly
not the case for files. The implication is that GRASS tape
reading commands which make theses assumptions about the input
device won't work on files (ie data copied from the tape to a
file to get it onto a system which doesn't have a tape drive).
