v.in.arc
jrk6f at uva.pcmail.Virginia.EDU jrk6f at uva.pcmail.Virginia.EDU
Mon Jan 13 11:52:42 EST 1992
I am having trouble using the v.in.arc command. The error message
"cannot find ARC-INFO lines file" is displayed.  I have tried
putting the lines and points files from the ARC 'ungenerate'
command in several different directories.  Is there a specific
file naming convention for these files different than adding a
.lin and a .pts after the filename?
Jim Klein 804-924-6438
