CD ROM IMPORT PROBLEM
Mary Martin martin at zorro.cecer.army.mil
Fri Jan 24 10:18:42 EST 1992
did you first make a dlg directory under your current $LOCATION,
and then copy the CD ROM files into it, before running v.import?
(check out the man entry for v.import.)
(To see whether you already have a dlg directory in your
current $LOCATION, you can type "ls $LOCATION" )
