s.surf.idw
Michael Shapiro
shapiro at zorro.cecer.army.mil
Mon Jul 6 17:54:17 EDT 1992
idw stands for "inverse distance weighting" which means that for
a given location to be interpolated, N known points "near" to
this point are selected and the z values for the N points are
averaged to form a z value for this location. The "average" is
weighted - points farther away are given less weight than points
nearby. The value for N is chosen by the user. The points
selected are the N points nearest the location to be
interpolated. The distance measure is Euclidean for UTM and
other planimetric grids, geodesic distance for lat-lon.
r.surf.idw and s.surf.idw differ only in that the known points
are posted to the center of gird cells in r.surf.idw whereas in
s.surf.idw the know points are not so constrained.
| I would like some information on the method used to
|generate the surface with s.surf.idw. What method was used? Is
|it similar to the "moving average" technique (Geo.
|Stats.--J.C.Davis)? Does it use the Pythagorean equation? Are
|s.surf.idw methods similar to the methods used in r.surf.idw?
|What would be a good reference for s.surf.idw?
|Regards,
|Bruce Wylie
Michael
