GRASS color tables
Michael Shapiro
shapiro at zorro.cecer.army.mil
Tue Jul 7 09:44:03 EDT 1992
GRASS color tables are NOT generated with any knowledge about the
display device. The number of colors in the color tables for
raster maps depends only on the the number of categories in the
raster map.
Image processing in GRASS does not treat the "image" files any
differently than raster maps. To create a color composite from 3
bands of R,G,B, GRASS has to make a raster "map" to which it can
assign colors that give a reasonable appearance when displayed.
The color composite routines is GRASS (i.composite, i.median) use
a color cube with 6 levels of red, green and blue (ie 216
colors). The resultant "image" is a "map" with this color cube
as the color file and categories assign to match the nearest
color in the cube.
Also, GRASS display capabilites only assume the display devices
use lookup tables, not 24 bit RGB planes etc. The current GRASS
drivers have no protocol for using 24 bit displays as they were
intended to be used. When GRASS is fully converted to use X-
windows hopefully this will change.
|I'm using an 8-bit display to view our raster data. I've examined the
|support files that reside under $GISBASE/colr and colr2 to find that
|the number of categories/colors in these files never exceeds 215
|(why isn't this max. value = 256?).
|I would like to know how colortable information is stored and 8
|bit information differentiated from 24 bit. Would the number of
|colors stored be any different if we were using a 24-bit device?
|How is the colormode setting (fixed vs. float) affecting the way
|these data are communicated to the hardware?
Michael
