interpolation programs
Dave Gerdes
dpgerdes at zorro.cecer.army.mil
Thu Jul 16 13:04:23 EDT 1992
> Date: Thu, 16 Jul 92 13:31:59 EST
> From: simon at cerberus.earth.monash.edu.au (Simon Cox)
> Message-Id: <9207160331.AA02871 at cerberus.earth.monash.edu.au>
> Sender: lists-owner at amber.cecer.army.mil
> Reply-To: grassu-list at amber.cecer.army.mil
> Precedence: Bulk
> Subject: interpolation programs
> Are there any interpolation programs for grass out there EXCEPT
> the idw pair?
> Inverse distance weighting may be fast and easy, but
> it does not produce very good results for some types of problem -
> eg if you have a "surface" which you *know* is smoothly varying,
> (eg geophysical data)
> then some form of surface fitting (polynomial, spline, etc) can be
> better - it allows you to find peaks between the data points, whereas the
> idw algorithm will NEVER produce a value higher (or lower) than
> the surrounding values.
> Thanks for your assistance
> Simon Cox
> Dept of Earth Sciences
> Monash University
> Clayton, Vic 3168 Australia
We have a program which uses thin plate splines. I have been meaning to
put it out for distribution but everytime I think I will, the programmers
come up with another major enhancement. I will try to get it out
this week for you. It is called s.surf.tps. It uses site
file data. I will include the source for a program which will dump
out every point from a labeled vector file as site info. With that, you
can convert contour data to site to be used as input.
Dave Gerdes
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
dpgerdes at cerl.cecer.army.mil
(217) 352-6511 x591
