paint output to file
Darrell McCauley
mccauley at ecn.purdue.edu
Fri Jul 17 16:23:21 EDT 1992
>Allan Branscomb (allanb at oregon.uoregon.edu) writes:
>> I want to capture the output of p.map to a file for transport to another site.
>> Can someone tell me how this is done?
>You can use p.select to choose ppm as your device driver, and p.map will save
>the file paint.ppm to your home directory (note: not your $LOCATION or current
>working directory if different than your home directory).
of course, you will not have any title, legends, etc, if you use this method.
--Darrell
