paint output to file
Chris Murphy murphyc at cgrb.orst.edu
Fri Jul 17 17:51:48 EDT 1992
Darrell McCauley (mccauley at ecn.purdue.edu) writes:
> [regarding using p.map to send output to a file]
> of course, you will not have any title, legends, etc, if you use this method.
Using p.map scripts, you can add titles, text, legends, grids, and barscales
to your output.  You must use scripts, however, as the interactive version of
p.map does not present you with these options.
Oregon State University / Entomology
Corvallis, Oregon USA
