Compiling GRASS on a Sun4
Michael Shapiro shapiro at zorro.cecer.army.mil
Wed Jul 22 17:43:16 EDT 1992
You`ve to the GRASS setup that it should create the grass4.0 command
in /geodata2/jac/grass. However you made the msitake of creating
a directory called /geodata2/jac/grass/grass4.0. You need to rerun the setup
and tell GRASS to install grass4.0 somewhere else (eg /usr/local/bin).
|	I've run into a problem compiling GRASS on a Sun4 running 4.1.1 . I get
|as far as general/gis in the next_step file before it fails. Per instructions
|on page 7 of the instlation guide gmake4.0 is on the path.
|	Here is the message from the console
|GISGEN: general/gis - Wed Jul 15 12:49:18 PDT 1992
|/geodata2/jac/grass/grass4.0/src/general/gis
|  mkdir OBJ.sun4
|  make -f OBJ.sun4/make.rules
|making /geodata2/jac/grass/grass4.0
|rm -f /geodata2/jac/grass/grass4.0
|echo '#!/bin/sh' > /geodata2/jac/grass/grass4.0
|sh: /geodata2/jac/grass/grass4.0: Is a directory
|*** Error code 1
|make: Fatal error: Command failed for target `unix'
|GISGEN failure at STEP: general/gis
Michael
