assigning colors to raster maps
Phil Chaney
phil at spock.uark.edu
Thu Jun 4 16:57:13 EDT 1992
> Hello,
> I am having difficulties assigning colors to a raster map with
> 44 different categories. I am using d.colors and changing the
> categories one by one to get the shading I want. The problem
> is that categories seem to change regardless of whether I change
> them or not. Clearly I am doing something wrong. I would
> appreciate any suggestions or others ideas.
> Thank you in advance.
> Pamela Phillips
> Center for Space Research, Imaging Lab
> University of Texas, Austin
> pamela at magellan.ae.utexas.edu
1. Try commands d.colormode fixed / d.colormode float.
There are a couple of things that you might consider!
making color assignments.
3. Try p.colors for making color assignments based on the colors
that your painter supports.
Good Luck,
-phil
Phillip L. Chaney Center for Advanced Spatial Technologies
Research Specialist National Center for Resource Innovations-SW
12 Ozark Hall
University of Arkansas
Fayetteville, Arkansas 72701
Phone: (501) 575-6159
(501) 575-4575
FAX: (501) 575-3846
E-mail: phil at spock.uark.edu
