GRASS, VAX and ULTRIX
Joe Vaughan jkv at dust.atmo.arizona.edu
Fri Jun 5 16:50:04 EDT 1992
> I am looking fo GRASS distributor for ULTRIX.
> Does anyone have any experiences with GRASS on VAX machines (I have
> VAXstation 3600)?
> Thanks in advance,
> 				Silvo
> 			kink at ijs.ac.mail.yu
> Centre of Scientific Research of the Slovene Academy of Sciences and Arts
> Silvester Kink Novi trg 5 61000 Ljubljana Slovenija
Silvo,
In case no one else tells you, CWU distributes Ultrix GRASS.
try
David Satnik (509) 963-1446
  SATNIKDB%CWU.BITNET at CORNELLC.cit.cornell.edu
for info.
I am running GRASS on a DECstation under ULTRIX.  I got the source codes over
ftp and unpacked and built them.  Problems did occur in the make operations,
occasionally.  If I remember correctly, the most frequent problem was that those
make rules which had a comment line starting with a tab within the rule were
confusing-- I changed these to a comment followed by a tab and they went through.
Good luck,
Joe Vaughan
 jkv at air.atmo.arizona.edu
Inst. of Atmo. Phys., U of Arizona. Tucson, AZ
