Erdas
Jerry Thompson thompson at zorro.cecer.army.mil
Thu May 21 10:11:08 EDT 1992
> Geez, I feel stupid, I figured out that erd2grass is the r.in.erdas command.
> I have replaced one problem with another... this is the output from when I
> run erd2grass:
> OPTION:   Name of erdas input file
>      key: erdas
> required: YES
> enter option > kong
> You have chosen:
>   erdas=kong
> Is this correct? (y/n) [y]
> OPTION:   The files for the n bands will be:
>            grasscellfile.1 ....... grasscellfile.n
>      key: prefix
> required: YES
> enter option > kong.1
> You have chosen:
>   prefix=kong.1
> Error can not open ERDAS file
> I have the erdas files stored under ./data/acheron/stacey/erdas
> with rw-r-r permissions. Where does erd2grass look for the data files?
> stacey at gis.wsc.monash.edu.au
r.in.erdas looks in the current directory for the files. You must either be in that directory, or specify the full path name to it.
Jerry Thompson
Spatial Analysis Systems Team
USA-CERL
