the new HP PaintJet XL driver in "incoming"
    Darrell McCauley
    mccauley at ecn.purdue.edu
    Thu Nov  5 04:36:07 EST 1992
Cleavy McKnight writes:
 > I have downloaded the file, but I have a couple of questions:
 > WHERE (in what directory) should I put the .tar file?
it does not matter where you put the tar file. However, when
you unarchive (un-tar) it, you should make sure that the source
goes to the proper place. See the directory /usr/grass/src/paint/Drivers
and the man page for tar (especially the -tvf option, to get you
started).
 > HOW do I tell GRASS that I want to print a file using this driver?
p.select
p.map
 > I've never printed anything from GRASS before.  In fact, I've never printed
 > ANYTHING from ANYWHERE on our SPARCStation before,
 > 'cause we didn't have a printer driver!
 > We have an SBUS Parallel card to connect our HP PaintJet XL to.  Does this
 > (parallel "communication") necessitate any customization of the new driver
 > files?
not that I recall... if something is on the BUS, it should automagically
be detected by the OS.
If you were using a serial device, however, you would edit /etc/ttytab
and then do a "kill -1 1"---perhaps this is what you were thinking of.
 > Thanks for your help!
 > ---Cleavy L. McKnight
 >    Geology Department
 >    Baylor University
 >    cleavy2 at earthlogic.baylor.edu
