g.region
Linda Bragg x6451
lbragg at ncrds.er.usgs.gov
Mon Nov 9 09:22:46 EST 1992
> Hello,
> I would like to know if it is possible to change the zone in the g.region
> command.
> I managed to change the North, South, West and East coordinates and also the
> resolution. The zone it is with is 16, but I'm working with a Landsat image
> from the south of Portugal that is in zone 29. So can anybody help me??
> Thanking in advance
> Cristina Seabra
> New University of Lisbon
> Lisbon, Portugal
> cis at fct.unl.pt
hi Christina,
I have been able to use g.region to change the zone. First though you
must edit the region file under your windows subdirectory. Edit the zone
appropriately. Then
run g.region as a command line:
g.region region=filename
For some reason this will change the zone if it has been edited in the
region file. g.region, as a menu driven command, will not let you
edit zone. Also edit PROJ_INFO so that the zones match.
Try this and see if it works.
Linda Bragg
U.S. Geological Survey
956 National Center
Reston, VA 22092
(703) 648-6451
FTS 959-6451
