p.map output
martijn at scanner.frw.uva.nl
Tue Nov 17 09:49:05 EST 1992
In view of the recent spate of messages about the things NOT appearing when
you're using p.map to create a hardcopy print, I would like to repeat my earlierquestion:
- we use the painters "preview" and "ppm". We can't produce screen or hardcopy
legends with those. Often the bottom line of a ppm file is missing. Sometimes
we get a short horizontal line below the image frame which I suppose is the
legend entry for something, though we never asked for it in the p.map file.
- since others have similar problems with the painters, could you GRASS devel
opers out there issue some kind of authoratitive statement about what the
painters can and can't do? Maybe this problem could be solved in time for
version 4.1?
Martijn van Leusen
