Extracting SPOTView images.
    Laxmi Prasad Musunur
    mlp at forestry.auburn.edu
    Mon Oct  5 16:23:08 EDT 1992
|Question 2:
|	Is there anyway one can buy a rectified image and then extract the image
|from the tape into an UTM location ?
|Laxmi P. Musunur
>(2) If you really want to extract directly into UTM location and have
>data already georeferenced you could do one of two things:
>(a) extract into an xy location and use unix commands to move all the
>data (raster as well as group) into the UTM location;
>(b) Remove the I_must_be_imagery_projection() call from the programs
>which extract images and this will allow you to put images directly
>into whatever location you wish. Be warned that the extraction
>utilities (with perhaps the exception of i.tape.other) may not know
>about rectified imagery.
>Note: you will have to run r.support to create a proper header for the
>images
>Michael Shapiro                        U.S. Army CERL
	I have few more questions about directly moving all data from
xy location to xy location. I feel that the first alternative is better.
Q. Would it still have the right zone information etc ?
	I'll try the first alternative and let you know if I have any further questions.
Thankyou for your time,
Laxmi P. Musunur (LP)
