Aggregation problems
Lars Schylberg larss at fmi.kth.se
Sun Oct 11 13:45:53 EDT 1992
>  # We are trying to aggregate cells (say 3x3 or 10x10) and compute
>  # an average for that entire area.
>  Try using r.neighbors to average values over a number of cells (odd number
>  required), and then cut the resolution down by the corresponding amount.
>  e.g.
>  Let's say you want to average in a 5x5 region for a map called "elev"
>  g.region rast=elev
>    Let's say this map is a 50m resolution
>  r.neighbors input=elev output=elev.avg method=average size=5
>    You now have the averages you want, but the original rows and cols
>  g.region res=250
>    250 = 5 * 50 (50 is the original res and 5 is the size input above)
>  r.mapcalc elev.avg=elev.avg
>    elev.avg gets resampled every 5 rows and 5 cols (cutting memory by 25 times)
Which value is the r.mapcalc picking when it is doing the resampling ?
Is it doing it this way:
X****X****X****X****
X****X****X****X****   =>   XXXX
********************        XXXX
or this way
**X****X****X****X**
********************   =>   XXXX
I think that r.mapcalc is doing it like in the first example and then the
result of the average operation will be that the average output map is shifted two
pixels towards west and two pixels towards north.
Please correct me if I'm wrong !!!
Lars
Lars Schylberg                    Email: larss at fmi.kth.se
Department of Photogrammetry
Royal Institute of Technology     Tel.   +46 8 790 86 33
S-100 44  STOCKHOLM, SWEDEN       Fax.   +46 8 790 66 10
