d.start.x0
Elwin Koster
ekoster at let.rug.nl
Tue Oct 27 09:51:46 EST 1992
Elwin Koster
University of Groningen
Architectural History
contact me by:
email - ekoster at let.rug.nl
phone - (+31) 50 636096
mail - PO Box 716
9700 AS Groningen
the Netherlands
X-Mailer: ELM [version 2.3 PL11]
Hi Amin,
I was reading your question, and I warn you I have also just started with Grass
but I remember that you have to change your monitorcap-file.
You can always locate where files are with the `where' or `whereis' command.
As I am correct there is an example monitorcap file delivered with Grass.
> Hi,
> I am reading the draft manual of 4.0. It is mentioned that
> the monitor should be started and then selected with d.mon.
> The script d.start.x0 is used and then x0 is selected.
> I am using openwindow ver.2 and running grass in an xterm
> window. Where is the d.start.x0 script? and what is the
> meaning of monitor?
> Thank you
> Amin
Good luck,
Elwin (Ekoster at let.rug.nl)
