d.start.x0
Michael Shapiro
shapiro at zorro.cecer.army.mil
Tue Oct 27 11:18:59 EST 1992
GRASS applications that perform graphics (programs likes
d.display, d.rast, d.vect) are written with a GRASS-defined
device-independent function calls. These calls transmit requests
to a program which is listening for such requests and executes
them for the specific device for which they were written - a
client-server type relationship. GRASS calls the program which
actually does the graphics the "monitor". In order to do any
graphics in GRASS you must start and select a monitor. Under X-
windows (or openwindows) you would start a monitor that knows
about X-window graphics by typing "d.mon start=x0" from within
GRASS. Of course d.mon needs to know how to actually start this
"monitor" and it gets its information from a file called
"monitorcap" in the GRASS etc/ directory.
When GRASS was installed on your system, whomever did the
installation would have had to (1) compile the XDRIVER and (2)
edit the monitorcap file to enable d.mon to know about the
XDRIVER and that it can be called as x0, x1, x2, etc.
There is no d.start.x0 script in GRASS although sites can write
one easily enough, since it would contain one line:
d.mon start=x0
Note: by default the start request also selects the device. GRASS
considers these requests distinct (starting then selecting) so
that users may have two or more monitors running and can switch
between them by just selecting different ones. But to make it
easier for the more common case of just one monitor, the start
also does a select (but of course, there is a flag to d.mon which
suppresses the select if you don't want the start to do a select).
|Hi,
|I am reading the draft manual of 4.0. It is mentioned that
|the monitor should be started and then selected with d.mon.
|The script d.start.x0 is used and then x0 is selected.
|I am using openwindow ver.2 and running grass in an xterm
|window. Where is the d.start.x0 script? and what is the
|meaning of monitor?
|Thank you
|Amin
Michael Shapiro U.S. Army CERL
email: shapiro at zorro.cecer.army.mil Environmental Division
phone: (217) 373-7277 P.O. Box 9005
fax: (217) 373-7222 Champaign, Ill. 61826-9005
