GRASS 4.0 and OpenWindows 3
jimg at tembo.rutgers.edu jimg at tembo.rutgers.edu
Fri Sep 4 08:53:35 EDT 1992
> We are currently running GRASS 4.0 on a SUN IPX under OpenWindows
> 2.  Does the XDRIVER currently available on the moon support
> OpenWindows 3?
> If so, what do I need to do to make GRASS work
> under OpenWindows 3?
> Specifically, do I need to download the entire GRASS source and
> recompile while running OpenWindows 3, or do I just need to
> replace the XDRIVER code in some other way?
> If not, is support for OpenWindows 3 planned?
> The IPX is my first Unix machine, so the more detailed the
> answer, the better.
> Any help would be appreciated.
We've been running GRASS under Openwindows 2 & 3 (simultaneously) for quite
a while now. No problems what so ever. Always try first and ask questions later.
Jim Gasprich				e-mail: jimg at ocean.rutgers.edu
Research & Support Slave		tel:    (908) 932-9631
Cook College Remote Sensing Center	fax:    (908) 932-8644
Rutgers University
PO Box 231
New Brunswick, NJ, O8903  	"Du bist mein Gweckman" - Anonymous Fascist
