GRASS FTP site
Michael Shapiro shapiro at zorro.cecer.army.mil
Thu Sep 17 07:43:27 EDT 1992
Does get README "|more" work? Or get README /dev/tty. I'm wondering
if long messages (like the output from ls -l) are causing buffer
overrruns or some such thing. I have no trouble with the server
at all, but of course I'm just down the hall from this machine.
I will pass the message on to the sysadmin person for the ftp
machine and see if he has any ideas
|>Here are no problems getting to moon but using the 'dir' - command.
|>Everytime following message appears:
|> 230 Guest login ok, access restrictions apply.
|> ftp> dir
|> 200 PORT command successful.
|> 425 Can't build data connection: Interrupted system service.
|I, too get the same results for either 'dir' or 'ls -l' ftp
|commands.  But I've noticed the following, which I mention
|here in case they may give some clues as to the problem:
|1. SOMEtimes the commands DO work properly, indicating an intermittent
|problem (most of the time they fail, for me).
|2. I have noticed that the 'ls' command seems to work all the time,
|even when the 'ls -l' version fails.
|Jim Aanstoos
|Research Triangle Institute
|email: aanstoos%gizmo at rti.rti.org
|       or jva at rti.rti.org
Michael Shapiro                        U.S. Army CERL
email:   shapiro at zorro.cecer.army.mil  Environmental Division
phone:   (217) 373-7277                P.O. Box 9005
fax:     (217) 373-7222                Champaign, Ill. 61826-9005
