**problems with DESQview/X PC running GRASS ** SOLVED **
Laxmi Prasad Musunur
mlp at forestry.auburn.edu
Sun Sep 20 23:21:57 EDT 1992
>| 1. When we start the monitor (d.mon start) it self it says
>| "Color: Can't set color 0"
>| 2. When we try to display a color vector map it doesn't use the
>|assigned color (infact no color can be displayed at all)
>| 3. When we try to display a raster map the monitor dies saying
>| "Segmentation fault"
>|Laxmi P. Musunur (LP)
>From: Michael Shapiro <shapiro at zorro.cecer.army.mil>
>Subject: Re: **problems with DESQview/X PC running GRASS, XDPYINFO
>Well, I think this is the problem. You only have one PsuedoColor
>visual and it isn't large enough. 16 colors isn't enough to run GRASS.
Thanks for your suggestion. That's precisely what we did before
we have seen this mail of yours. Yes, it worked with 256 colors.
Thankyou verymuch.
