d.menu
    John Cartwright
    johncc at picea.CFNR.ColoState.EDU
    Thu Sep 24 22:38:52 EDT 1992
Hello All,
I am having a problem with d.menu that I was hoping that someone could help with.
in using d.menu with a shell script very similar to one mentioned in the User
Manual (which I listed below) I am getting a X-windows error like the following:
  X Error of failed request:  BadMatch (invalid parameter attributes)
    Major opcode of failed request: 73 (X_GetImage)
    Serial Number of failed request:  629
    Current serial number in output stream:  629
  ERROR eof from graphics driver.
The problem only arises when command line options are used in addition to the
in-line file redirection.  Used separately there doesn't seem to be a problem.
I'm using a Sun IPC with OpenWindows 3 and the mwm.  I can't be sure but I think
that this used to work with OpenWindows ver 2 and olwm.  Anyway the shell script
is listed below.  I'd appreciate any suggestions to this problem.
d.menu bcolor=red tcolor=green dcolor=yellow size=5 << EOF
.T 25
.L 25
Output Scenarios:
Test1
Test2
Test3
Exit
EOF
--john cartwright
johncc at picea.cfnr.colostate.edu
