PC X-windows revisited
    Don Baird
    baird at bml4380.cpg.cdc.com
    Thu Sep 24 17:55:42 EDT 1992
To all
On September 17th, Joachim Wiesel (wiesel at ipf.bau-verm.uni-karlsruhe.de)
writes:
> HCL/exceed/W and Exceed have problems with colors and the x-monitor.
We too have used PCs as X-terminals.  For one show, I rented a cheap
386SX 16MHz clone, added a 3Com Ethernet card and Exceed.  The system
had a non-supported 1024x768 video setup, but nevertheless, Exceed
did successfully perform on that somewhat meager configuration.
The PC display attracted much notice during the show.  We ran an NCD
X-terminal and the PC side by side; no color problems were encountered
with the PC running Exceed.
Two things to keep in mind when considering a similiar setup:
  Most X-Terminals (NCD, etc) are 16" or larger, where most PC monitors
   are 14".  The larger screen does make a difference.
  Graphics performance of a PC vs an X-terminal may vary greatly.  The
   X-terminal does only one job - interface to the screen.  The PC, on the
   other hand, is a general purpose piece of equipment.  Upgrade of the
   PC graphics (Joachim referenced use of an ATI Graphics Vantage, with
   8514 mode) has the potential of making the PC X-terminal an even better
   choice
Exceed is also in use at CERL, the home of GRASS
Regards,
Don
   C O N T R O L   |           Control Data Systems, Inc.            |
     ___   ___     | Donald R. Baird           baird at dsr.cpg.cdc.com |
    / __|  __ \    | St. Louis, MO                      314-872-2237 |
   ( (__   __) )   |                              FAX - 314-872-2206 |
    \___  |___/    +- - - - - - - - - - - - - - - - - - - - - - - - -+
                   | "It's much easier to apologize than get per-    |
      D A T A      |  mission."    -    Adml. Grace Hopper           |
