is ps.map working?
James A. Farley
jim at cast.uark.edu
Thu Apr 1 10:52:14 EST 1993
>> William W. Hargrove wites
> GrassHoppers:
> Has anyone successfully used ps.map in 4.1beta successfully yet? I
> cobbled up a PostScript device under $GISBASE/etc/paint/ps.devices (not
> psdevices, as the g.manual page states) called phaserps like so:
> level: 2
> page width: 8.5
> page height: 11.0
> top margin: 0.25
> bottom margin: 0.25
> left margin: 0.25
> right margin: 0.25
> resolution: 300
> and I can select it with ps.select, no problem. But when I try to use
> ps.map, after answering all of the prompts, when I hit return, I get an
> immediate Segmentation fault. It does write out the script file, if I
> request that, but only creates a zero-length postscript file.
> Anyone know anything about this? It looks like a nice tool. Anybody
> know an E-mail address forPaul Carlson, USDA, SCS, NHQ-CGIS?
I've had the same problem however when i run ps.map in the command line
form using a prepared input file i get ps output to the printer just
fine.
James A. Farley Technical Director, CAST/NCRI-SW
12 Ozark Hall, Univ. of Arkansas
jim at cast.uark.edu Fayetteville, AR 72701
Voice: (501) 575-6159 FAX : (501) 575-3846
