m.eigensystem compilation problems
Anantha Prasad
prasad at ghat.inhs.uiuc.edu
Fri Apr 2 11:11:04 EST 1993
I have been trying to compile m.eigensystem (in src.contrib) in grass4.1beta and am running into the foll. problems: Can anybody shed light please?
ghat# gmake4.1beta
SRC = /ever/grass4.1b/source/src
CMD = /ever/grass4.1b/source/src/CMD
HEADER = sun4
ARCH = sun4
GISBASE = /ever/grass4.1b/source/sun4
VERSION = 4.1beta Spring 1993
/ever/grass4.1b/source/src.contrib/CERL/misc/m.eigensystem
make -f OBJ.sun4/make.rules
f77 -o /ever/grass4.1b/source/sun4/etc/bin/contrib/inter/m.eigensystem OBJ.sun4/main.o OBJ.sun4/balanc.o OBJ.sun4/balbak.o OBJ.sun4/cdiv.o OBJ.sun4/elmhes.o OBJ.sun4/eltran.o OBJ.sun4/hqr.o OBJ.sun4/hqr2.o OBJ.sun4/rg.o
ld: /ever/fort/fort/libF77.sa.1.1: warning: table of contents for archive is out of date; rerun ranlib(1)
ld: /ever/fort/fort/libm.a: warning: table of contents for archive is out of date; rerun ranlib(1)
ghat# cd /ever/grass4.1b/source/src/CMD
ghat# MAKELINKS.sun4
NOTE: When I run m.eigensystem, it hangs.... and when I do Cntrl-C
GRASS 4.1beta > m.eigensystem
*** Interrupt = signal 2 code 0
Cant open file for traceback
Expect output on terminal
Note: Line numbers for system and library calls may be incorrect
Begin traceback...
Called from 0xf6eb2c4c , at 0xf7ffeac8, args=0x2 0x0 0xf6f939fc 0xf7004ad8
Called from 0xf6ebb8e8 , at 0xf7ffebc8, args=0x0 0x35280 0x80 0x1
Called from 0xf6f45fc0 , at 0xf7fff4d8, args=0x2c698 0xffffffff 0x3 0x0
Called from 0xf6f46194 , at 0xf7fff538, args=0xf6f45f34 0xf8390fb4 0xf6f460f0 0x80
Called from 0x2300 , at 0xf7fff598, args=0x2a2d0 0x1 0x2c948 0x4
Called from 0xf6f40c38 , at 0xf7fff788, args=0x0 0x2c6ac 0x1 0x2e000000
Called from 0x2064 , at 0xf7fff7e8, args=0x0 0x10 0xf7fff854 0x2a000
End traceback...
Traceback has been recorded in file:
/ever/grass4.1b/source/sun4/bin/m.eigensystem.trace
HELp!! (prasad at ghat.inhs.uiuc.edu)
