help for d.3d images
    Ronald Thomas
    ront at niwot.CFNR.ColoState.EDU
    Tue Apr 13 10:27:17 EDT 1993
Given the limitations of d.3d (compared to SG3d), any "jazzing" up of the
image to be displayed has to be done prior to using d.3d.
Explore the shade.rel.sh command and develop a good shade relief model for your
your area, using "natural" sun angles.
Use d.his to "blend" the shade relief model into your image (h_map=data.map
i_map=shade.map, ignore the saturation map).  This works real well when
the color for zero (0) is white.  Use "out=" option to save output.
Drap the output of d.his over your elevation data in d.3d.
This map is no longer data, merely a graphic, but GREAT results are
possible.
   Ronald Thomas                         ^  ront at meeker.cfnr.colostate.edu
    Natural Resources Spec. (GIS)        ^
     Resources Management Division       ^   Phone: 303-586-3565  x285
      Rocky Mountain National Park       ^          700-323-7285  (FTS)
       Estes Park, CO  80517             ^   FAX:   303-586-4702
