v.in.arc on GRASS4.1beta
nick at ikaros.harvard.edu nick at ikaros.harvard.edu
Wed Apr 21 17:26:16 EDT 1993
>When using this command we get the following message:
>v.in.arc type=line lines_in=okla.try vector_out=okcounties
>v.in.arc: Coverage type = line
>Cannot find ARC/INFO lines file <okla.try>
Make sure that your lines file is in a directory called /arc in your
current mapset, and that you are calling v.in.arc from within that
directory.
