using tcsh with GRASS ??
Ferdinando Villa
villa at sparrow.bio.unipr.it
Tue Apr 27 05:22:27 EDT 1993
> Has anyone experienced problems using tcsh for the GRASS interface ??
> Mine seems to dive-bomb, putting me outside the GRASS start-up
> script for some odd reason.
> I can't really elaborate on the problem too much. I am unsure as to
> which flavor of tcsh we have (we may be going to the *REAL* tcsh, as
> our computer jockeys say), and have been unable to track down the
> specifics at this point. I'm doing the usual post first, figure it out
> later sort of thing.
> Any info (or flames) greatly appreciated,
> Jim Gasprich jimg at ocean.rutgers.edu
> Center for Remote Sensing and tel -> (908) 932-9631
> Spatial Analysis, Rutgers U. fax -> (908) 932-8644
Are you using GRASS 4.1beta or 4.0? In the first case, support for tcsh
is built in and you should have no problems as long as your tcsh is working
correctly. If you use 4.0 the startup script needs some minor modifications
to work right. I made these modifications, so if you need it you can email
me.
Hope this helps
Ferdinando Villa, dr.
Institute of Ecology Direct phone: +39-521-905615
University of Parma FAX: +39-521-905665
Viale delle Scienze e.mail: villa at eagle.bio.unipr.it
43100 Parma, Italy villa at sparrow.bio.unipr.it
