nodes in vector output from p.map
Bret J. Ruby, GBL, 855-0522 RUBY%BLACK.DECnet at indiana.edu
Fri Aug 6 11:54:10 EDT 1993
I've been using p.map to produce postscript output of a vector
map patched together from USGS DLG hydrography coverages
(ppmtopgm paint.ppm|pgmtops>outfile).
The problem is that stream origins and terminations are
marked by rather prominent nodes on the output, producing a
busy-looking map. Is there any way to suppress these on the output?
Thanks in advance,
bjr
Bret James Ruby			         Voice:        (812) 855-9544
Glenn A. Black Laboratory of Archaeology   Fax:        (812) 855-1864
9th and Fess Streets	                Bitnet:         bruby at indiana
Bloomington, IN   47405		      Internet:     bruby at indiana.edu
