XDRIVER & Solaris2.2 : reprise
    Ronald Thomas
    ront at niwot.CFNR.ColoState.EDU
    Thu Aug 12 13:07:17 EDT 1993
GRASSuser's;
Thanks to some advice received yesterday, I was able to compile MOST of
GRASS4.1 on a SPARClassic running Solaris2.2.   I integrated the update
code prior to compilation.
			<HOWEVER>
I am not able to compile the ../../XDRIVER/XDRIVER directory:
a more COMPLETE form of this error message follows my signature block.
  SRC     = /data2/grass4.1.code/src
  CMD     = /data2/grass4.1.code/src/CMD
  HEADER  = classic
  ARCH    = classic
  GISBASE = /opt/grass4.1
  VERSION = 4.1 Spring 1993 Update package 1
/data2/grass4.1.code/src/display/devices/XDRIVER/XDRIVER
  make -f OBJ.classic/make.rules
rm -f OBJ.classic/SWITCHER.o
gcc -O2 -w -D_NO_PROTO -DX11R3 -I/usr/openwin/share/include -I/data2/grass4.1.code/src/include -DUSE_TERMIO -c SWITCHER.c
SWITCHER.c: In function `main':
SWITCHER.c:159: too many arguments to function `setpgrp'
*** Error code 1
make: Fatal error: Command failed for target `OBJ.classic/SWITCHER.o'
I am using these options in the "head" file
CC                  = gcc
ARCH                = classic
UNIX_BIN            = /opt/grass4.1/local/bin
DEFAULT_DATABASE    = /data2/romo
DEFAULT_LOCATION    = working
COMPILE_FLAGS       = -O2 -w
LDFLAGS             = -s
XCFLAGS             = -D_NO_PROTO
XLDFLAGS            =
XINCPATH            = -L/usr/openwin/share/include
XMINCPATH           =
XLIBPATH            = -L/usr/openwin/lib
XTLIBPATH           = -L/usr/lib
XMLIBPATH           = -L/usr/lib
XLIB                = -lX11
XTLIB               = -lXt
XMLIB               = -lXm
XEXTRALIBS          = -lsocket -lnsl
TERMLIB             = -ltermlib
CURSES              = -lcurses $(TERMLIB)
MATHLIB             = -lm
#                   LIBRULE = ar ruv $@ $?
#                   LIBRULE = ar ruv $@ $?; ranlib $@
#                   LIBRULE = ar ruv $@ $?; ar ts $@
#                   LIBRULE = ar rc $@ `lorder $(OBJ) | tsort`
USE_TERMIO          = -DUSE_TERMIO
USE_MTIO            = -DUSE_MTIO
USE_FTIME           =
DIGITFLAGS          =
VECTLIBFLAGS        = -DPORTABLE_3
GETHOSTNAME         = -DGETHOSTNAME_UNAME
 Once agian, THANK YOU for any help offered!!
   Ronald Thomas                         ^  ront at meeker.cfnr.colostate.edu
    Natural Resources Spec. (GIS)        ^
     Resources Management Division       ^   Phone: 303-586-3565  x285
      Rocky Mountain National Park       ^          700-323-7285  (FTS)
       Estes Park, CO  80517             ^   FAX:   303-586-4702
All error messages that show in the failure of XDRIVER compilation
/opt/grass4.1/local/bin/gmake4.1 XDRIVER
gcc -O2 -D_NO_PROTO -DX11R3 -I/usr/openwin/share/include -I/data2/grass4.1.code/src/include -DUSE_TERMIO -c SWITCHER.c
SWITCHER.c:162: warning: passing arg 2 of `signal' from incompatible pointer type
SWITCHER.c:164: warning: passing arg 2 of `signal' from incompatible pointer type
SWITCHER.c:183: warning: passing arg 2 of `signal' from incompatible pointer type
SWITCHER.c: At top level:
SWITCHER.c:866: warning: `get_command' was declared implicitly `extern' and later `static'
SWITCHER.c:894: warning: `timeout' was declared `extern' and later `static'
SWITCHER.c:899: warning: `rec' was declared implicitly `extern' and later `static'
SWITCHER.c:915: warning: `rectext' was declared implicitly `extern' and later `static'
SWITCHER.c:928: warning: `_rectext' was declared implicitly `extern' and later `static'
SWITCHER.c:939: warning: `get1' was declared implicitly `extern' and later `static'
SWITCHER.c:967: warning: `read1' was declared implicitly `extern' and later `static'
SWITCHER.c:981: warning: `send' was declared implicitly `extern' and later `static'
SWITCHER.c:988: warning: `sendtext' was declared implicitly `extern' and later `static'
SWITCHER.c:994: warning: `catch' was declared `extern' and later `static'
SWITCHER.c: In function `catch':
SWITCHER.c:995: warning: passing arg 2 of `signal' from incompatible pointer type
SWITCHER.c:1014: warning: `RESULT' was declared implicitly `extern' and later `static'
SWITCHER.c:1094: warning: `invent_pad' was declared implicitly `extern' and later `static'
SWITCHER.c:1170: warning: `free_item' was declared implicitly `extern' and later `static'
SWITCHER.c:1189: warning: static declaration for `find_item' follows non-static
SWITCHER.c:1205: warning: static declaration for `new_item' follows non-static
SWITCHER.c:1230: warning: `close_mon' was declared `extern' and later `static'
*** Error code 1
Current working directory /data2/grass4.1.code/src/display/devices/XDRIVER/XDRIVER
*** Error code 1
make: Fatal error: Command failed for target `all'
GISGEN failure at STEP: src/display/devices/XDRIVER
