help
Brian Kierstead brian at ug.cs.dal.ca
Wed Aug 18 14:20:35 EDT 1993
The region in GRASS is the geograohic location you are working in.  The
default region is the region you specify when you create the location
and the one that GRASS will start with each time you begin a session with
this location.  The region can be changed once you are in GRASS with the
g.region command, so you aren't writting anything in stone when you set
the default.
Brian.
