Adding *.man files to online manuals
Fri Aug 20 16:21:06 EDT 1993
Doug Hersh (dhersh at lupine.mbl.edu) writes on 20 Aug 93:
>How does one add the *.man files recieved with contributed programs
>so that they appear in the g.manual listing, (command) help, and
"SRC" below can be found by running 'gmake4.1' or by looking
at the output of 'more `which gmake4.1`'
cp the man page to SRC/../man/man4, then run 'gmake4.1' in SRC/../man
running 'command help' does not depend on the man page
for the g.help command, you need to create something in
SRC/../man/help.src and run the appropriate gmake.
For any programmers listening, I've found that the following
target in a Gmakefile works good (so that this is done automatically).
MSEC=4
MDIR=$(SRC)/../man/man$(MSEC)
MUTL=$(SRC)/../man/utilities
man:
-cp s.semivar.man $(MDIR)/s.semivar
nroff $(MUTL)/man.version $(MDIR)/.class-header \
$(MUTL)/man.header s.semivar.man $(MDIR)/.class-notice \
> $(GISBASE)/man/$(MSEC)/s.semivar
--Darrell
Date: Fri, 20 Aug 1993 15:19:48 -0500
Sender: grass-lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list at max.cecer.army.mil
Subject: Re: Adding *.man files to online manuals
There's probably a cleaner way to do this, but I put this line in
the Gmakefile for contributed programs:
cp doc/catman $(MAN1)/$(PROG)
where:
MAN1 is defined somewhere in the Gmake process
PROG is defined in the Gmakefile
catman is a file created by "nroff -man [manpagefile] > catman"
Since you've already compiled the programs, you could just look in
the OBJ.*/make.rules file to track down the definition of MAN1 and
put a "catman" file for each program there. Actually, I think
something like MAN3 or MAN4 is probably the "official" place for
contributed programs, but I'm not sure. (why not call them MAN_ALPHA,
MAN_CONTRIB, etc?).
bill
Thanks, Darrell.
Note that using my method, you won't get all the version, class-header,
class-notice stuff.
bill
Thanks, Darrell and Bill
________________________________________________________________
Doug Hersh Boston University Marine Program
dhersh at lupine.mbl.edu Marine Biological Laboratory
(508)548-3705 ext. 516 Woods Hole, MA 02543
