utm spheroid clarke 1886
    Gerald I. Evenden
    gie at charon.er.usgs.gov
    Tue Dec 14 10:33:56 EST 1993
>Date:         Tue, 14 Dec 93  08:52:48 CST
>From: "garvinc at sill-emh.army.mil (Chris D Garvin)" <GARVINC at SILL-EMH.ARMY.MIL>
>Subject:      utm spheroid clarke 1886
>To: <grassu-list at max.cecer.army.mil>
>Regarding the difference between clark 66 and clark 88; there will definatly
>be a differance between the two projections! The difference will be on the
>order of a few hundred feet on both the x and y axis. I have also had problems
>with some programs not having the correct projection. This is especially true
>with the SCS MAPGEN interface.
>regards,
>Chris D Garvin--Ft Sill,OK
Two questions:
1) If there is a Clarke 1888 ellipsoid, what are its parameters?
2) What do you mean by "not having the correct projection" above?
Thanks.
Gerald (Jerry) I. Evenden   Internet: gie at charon.er.usgs.gov
voice: (508)563-6766          Postal: P.O. Box 1027
  fax: (508)457-2310                  N.Falmouth, MA 02556-1027
