Inputting DEM data into GRASS
Michael Shapiro shapiro at zorro.cecer.army.mil
Wed Feb 17 12:39:50 EST 1993
In info.grass.user you write:
>>John Miller writes:
>>>     {deleted stuff describing a DEM file format}
>>>     What is the best way to import this data into a GRASS
>>>     mapset?   Is my only option to convert the data to a
>>>     format suitable for r.in.ascii?
>Katarina writes:
>>You can import the data as sites, using s.in.ascii, and then convert it
>>to raster, using one of the options in s.menu. That's how I did it when
>>I imported DEM data for an area in British Columbia.
>Thank you for spending the time to reply to my request.  I tried
>your suggestion.
>s.in.ascii  worked fine as far as I can tell (once I worked out
>that I had to make my Latitude values negative for the Southern
>Hemisphere).  A line in the file looks like:
>        146.005|-19.5|313
>However, (isn't there always an however :-) I can't get s.menu
>to work in the way I require.  I choose option 6 "Convert site
>list to raster file (0/1)" and choose one cell per site.  The
>resulting raster file seems to only have  zero values for the
>elevations.
>'ve tried editing the site_lists file to include a  #
>character before the "description" field as suggested in the
>manual, so that the line in the file shown above looks like:
>        146.005|19.5|#313
>This didn't seem to work either.
>I checked the current region was correct with g.region.
>Any clues?   Is there a problem concerning expressing the LAT/
>LONG values in degrees and thousandths of degrees ?
The problem you are encountering MAY be the 4.0 version of s.menu.
s.menu was originally written to only use integer coordinates,
truncating the coordinate values at the decimal point. This has
been fixed - the update is on moon.
Michael Shapiro U.S. Army CERL
Environmental Division
P.O. Box 9005
Champaign, Ill. 61826-9005
email:   shapiro at zorro.cecer.army.mil
phone:   (217) 352-6511  ext 526
fax:     (217) 373-7222
