The 175 meter error is of the right magnitude to be caused by improper matching of UTM "spheriods". The DLG data was likely produced referenced to the "clark66" (NAD27) spheroid, and your GPS may be using a more modern spheroid. You could use m.ll2u and m.u2ll to convert your GPS control points to the different datum. Jim Hinthorne GIS Lab GIS Lab
