rasterizing digitized contour maps
Bob Harrington bobh at hwr.arizona.edu
Thu Feb 25 12:37:54 EST 1993
> You should also look at r.surf.contour and s.surf.tps, both methods
> of surface construction.
Yes, r.surf.contour looks like what I should be using. I'll
set it to work also.
> > 2. I launched r.surf.idw2 yesterday on a SPARC 10,
> > and it is still working this morning. The map is
> > 834 by 989. How long is this going to take?
> It should have been finished by now. Did you make the interpolation
> very involved (like using the nearest 24 points) ?
I just went with the default of 12.
Cheers,
Bob Harrington
Hydrology and Water Resources
University of Arizona
