MAPGEN & hp 7475's
Linda Bragg x6451
lbragg at ncrds.er.usgs.gov
Thu Jan 14 12:25:12 EST 1993
If you are using the plotter command in MAPGEN, it has a -r option
which rotates the map 90 degrees
Linda Bragg lbragg at ncrdsr.usgs.er.gov
USGS
956 National Center
Reston, VA 22092
703-648-6451
> GRASSuser's (MAPGENuser's?),
> Still plugging along, we've got MAPGEN compiled, identified to our
> system, and producing maps. We are using a HP 7475A, which handles 8 1/2
> by 11" or 11" by 17" paper. My question is in ROTATING the image when using
> the smaller paper.
> I can physically switch to the rotate function on the plotter, but
> the function is over-ridden by the code coming from MAPGEN. Does anyone have
> a work-around for this? It's something to do with the 'hpgl' language and the
> "RO" command, I believe, I just don't know what to adjust.
> Any suggestions offered can be sent to me directly, as the info on
> this particular plotter might not be of interest to the entire list.
> Thank you.
> Ronald Thomas ^ ront at meeker.cfnr.colostate.edu
> Natural Resources Spec. (GIS) ^
> Resources Management Division ^ Phone: 303-586-3565 x285
> Rocky Mountain National Park ^ 700-323-7285 (FTS)
> Estes Park, CO 80517 ^
