Configuration Setup
Darrell McCauley
mccauley at ecn.purdue.edu
Tue Jan 19 12:58:51 EST 1993
ask each user to do the following:
install -d ~/grass/data # or something appropriate
cd ~/grass/data
foreach location (/mcae/grass.data/*)
if (-d $location) then
mkdir $location
cd $location
foreach mapset ($location/*)
if (-d $mapset) ln -s $mapset
end
cd ..
endif
end
Then, when they run grass, have them put their own directory
name when it asks for a DATABASE (e.g. /home/icil64/joe_user/grass/data).
The set of csh commands given above untested, but I think that you
can get the jist of what's going on. Try it out, package it up in a
shell script, and have each new grass user run it (maybe you could
even put a hook in GIS.sh to check for the existence of ~/.grassrc
to do this... oh, one is already there. just modify it:
| if [ ! -f $GISRC ]
| then
set_up_stuff_for_icil64.csh # make users use their home dir for data
| cat $ETC/gis_intro
| echo ""
| echo "Hit RETURN to continue"
| read ans
| fi
--Darrell
MINOJA at icil64.cilea.it (MINOJA at icil64.cilea.it) writes on 19 Jan 93:
> Hello Grass User,
> On my machine as root user I have installed grass4.0 using this
> SETUP configuration.
> ARCH = Convex10.0
> GISBASE = /mcae/GRASS/Convex10.0
> UNIX_BIN = /mcae/GRASS/bin
> DEFAULT_DATABASE = /mcae/grass.data
> DEFAULT_LOCATION = spearfish
> This configuration is not good for me because every grass user may write
> own data into the disk /mcae.
> I wish to configure SETUP in a such way so as my users for default write
> data into own home directory.
> Note that into /mcae/grass.data I have the grass demo files and I wish
> that my users are able to read (read only!) this information.
> Thank You very much
> Bruno
>______________________________________________________________________________
>Bruno Minoja
>Cilea (Consorzio InterUniversitario Lombardo Elaborazione Automatica)
>Via R. Sanzio 4
>Segrate Milano Italia
>E_MAIL : minoja at icil64.cilea.it
