GRASS and MacX
mike camann
camann at pick.uga.edu
Thu Jul 1 18:13:27 EDT 1993
Can anyone tell me how to display a graphics monitor on a Mac running
MacX?
GRASS 4.1 is running on a Sun server, I'm logged into the Sun from the
Mac. Access control is turned off at the Mac end and the DISPLAY
variable is
set to Mac_hostname:0.0 on the Sun end. When I try to open a monitor,
i.e. d.mon start=x0, GRASS returns a series of X error codes and
finally says
that the monitor is not started- stating the obvious. I've seen
numerous
postings to this list that imply that it _should_ work, so I assume
that I'm not
doing something correctly. Can anyone help?
Thanks....
Mike Camann
camann at dial.pick.uga.edu
