shell scripts in GRASS4.1
    Jane Rossing
    rossing at swlab.aben.cornell.edu
    Wed Jul 14 11:28:58 EDT 1993
We are having trouble getting scripts to work in 4.1.  We follow exactly the same
procedure as worked well in 4.0 (write a script in "vi", chmod, then just run it).
In GRASS 4.1, however, the error message "command not found" is always returned,
even when the file is right there.  We have tried putting scripts in different
directories but haven't found one where it will run.  This was not a problem in 4.0.
Does anyone have any ideas?  Thanks a lot -- we're mystified.
Jane Rossing
