Try running the unix command rehash . Don't ask me what it does. But it fixes that problem for me. If that doesn't work make sure that . (current directory) is in you path setting. For a test try running the shell script as ./script . If that works then your path setting doesn't have the current directory (or . ) in it. Mark Johnson USACERL
