shell scripts in GRASS4.1
Greg Koerper
greg at towhee.cor2.epa.gov
Wed Jul 14 12:03:39 EDT 1993
> We are having trouble getting scripts to work in 4.1. We follow exactly the same
> procedure as worked well in 4.0 (write a script in "vi", chmod, then just run it).
> In GRASS 4.1, however, the error message "command not found" is always returned,
> even when the file is right there. We have tried putting scripts in different
> directories but haven't found one where it will run. This was not a problem in 4.0.
> Does anyone have any ideas? Thanks a lot -- we're mystified.
Not sure what you mean by "right there." But do an echo $path while running
GRASS. If you cannot find " . " in the list, then the current directory is NOT
being searched for the command name.
> Jane Rossing
