R.WATERSHED RUN-TIME QUESTION.
Merlyn Paulson larch at lamar.ColoState.EDU
Mon Jul 26 10:29:30 EDT 1993
R.watershed has been running since 8:15AM 8/22 (today is 8/26) on the
following dataset (current progress follows):
The output from r.watershed will be divided into watershed
basins.  There are two possible methods of tabulating the information:
1) by only including data pertaining to the basin itself, or 2) using
data from the basin, and all basins upstream of it.
Would you like the data organized:
1) Basin only
2) Basin and upstream
3) Both
OR 0) to cancell program
Your choice: 1
OK, seg should start running now using the following form:
/usr3/grass4.0/etc/water/seg el="elevation at PERMANENT" de="lakes at PERMANENT" t=1 ba="basin1" ar="relate1" ac="accum1"
SECTION 1 beginning: Initiating Variables. 5 sections total
    segments in row:    167
segments in columns:    165
     total segments:    27555
      open segments:    213
SECTION 1b (of 5): Determining Offmap Flow. Percent Complete:
SECTION 2: A * Search.                      Percent complete:    4%
MY QUESTION IS THIS:
1) Basin only
3) Both
Your choice: 1
      open segments:    213
DOES IT MAKE SENSE THAT IT TAKES APPROXIMATELY 36 HOURS (SUN IPX) TO
KNOCK OFF EACH PERCENT IN SECTION 2: A + Search?
I really need to get this done, so am extremely hesitant to kill the
job and begin again.
Any suggestions would be very greatly appreciated.
Thanks in advance...
Merlyn Paulson, Prof.
Landscape Sciences & GIS                         Telephone (303)491-7594
Colorado State University                         Faxphone (303)491-7745
Fort Collins, Colorado 80523            E-mail larch at lamar.colostate.edu
